my compression test through all 4 cylinders starting from where cam gear is.. 205 210 215 205.. are these okay numbers?
btw there is oil in the spark plug tubes.. i had this same problem with my previous accord and i got the lower spark plug tube seals and the upper ones and valve cover gasket and it fixed the problem.. im hoping this is the same problem?
