Heya. I have a coolant leak as the title says and it is underneath the intake..In the middle-ish maybe toward the driver side some..
I just had the oil cooler hoses replaced and new hose clamps put on as well...
It seems to be a hose leaking, but it's hard to see under the intake... ( I have looked at it from the bottom side as well.)
I was wondering what it could be other than my oil cooler hoses?
And what is the best way of getting to those hoses? The guy I had replace the oil cooler hoses and O-ring said he went in from the bottom..(90$!)
Also I think my car is building too much pressure in the coolant system and therefore leading to premature hose failure..(maybe not...im not sure.) Any ideas what would cause this? At first I was filling the radiator with cold water all the way full like a dummy...I know better now. (It doesnt seem to want to bleed out properly unless it is topped off on coolant.) Now I am not overfilling and it leaks only (so far) when I go over 3,000 RPMs-ish.
What is/could be causing these leaks? Other than the fact that it might just be old hoses..
Maybe a slightly cracked head or gasket? (The gasket is less than a month old..) I was told to start the car and rev it up a few times and feel the radiator hose for pressure, and when I did it had none.
