Ok, I need some help....I think I blew a fuse or something but let me give u guys the background story as it happened.
I've been experiencing intermediate starting issues with my car(normally after letting it sit in the scorching Fl heat for 8 hours while working) which made me think it was the main relay because it normally started after like 10 - 15 mins of trying. My step dad keep thinking its the coil (internal - 99 CG accord) but I didnt think so.
Had the same starting prob leaving work today so I drove 35 mins to this little korean place and picked up a new main fuel relay for $26. Popped it in, car starting, and drop home. 5 mins away from home i noticed a CEL (not sure how long its been on).
I assume it was due to the new relay so I did a few errands and went to my moms house to drop something off. After searching the web for a bit I found a thread on honda-tech how to check the CEL code similar to how we do the CB. I grabbed my paper clip and attempted it when I saw the paper clip sparked a little.
At this point, i thought OH SHIT, i fucked something up. Before my dumb move, the car was starting but after that little spark the car havent started and i noticed that the CEL light on the cluster DISAPPEARED. You know how when you turn your key to 2nd position and the dash lights up and u see the check engine light logo, maintenance, ABS, etc well now the CEL doesnt show up at all
I'm still lost on why this happened but something else happened, I can no longer shift my car outta PARK when the key is in the 2nd position like it did before ( 99 CG accord).
Well, nonetheless, i replaced the coil, check the wires and plugs (distributor cap/rotor are a week old) and still it cranks but no start.
My search on the web states it could be a lock out solenoid, brake switch, some fuses or blown brake light bulbs.
So tomorrow I will be checking all of the above but any input or pointers will be greatly appreciated.
I've had a long string of bad luck lately but im tryna stay positive
