Have you checked the fuse? does the motor make any noise at all?
Electric sliding seat belt doesn't work
Honda should fix it, there's a spot in the rear of the car, by the seat bottom that has an access for you to retract the belt so it's still usable if it should be stuck in the open position. It does take some time to crank it back though.
Check fuses first, then the connections under the passenger seat, then take it to a dealer.
Unless someone had rewired your car poorly, I guarantee that the radio fuse didn't fix the seatbelt. Maybe you read the labels wrong.Originally posted by magicdragonwheni bought my cb7 mines did'nt work i found a fuse blown in the engine bay box and it fix it check the radio fuse should me 7.5a but thats what my problem was
is this true honda will fix it even though the car is old?
because i have this too my seat belt doesnt slide open juss stays closed on my driverside. i always unclip it to get out and ive noticed wen im in hurry i keep smacking the window with the belt to put it onLast edited by sombra13; 08-03-2010, 06:33 PM.
