as title suggests this problem started for the first time 2 days ago, engine has 118,000 miles on it. and yes i have already researched and narrowed my probable causes. haynes manual and other sources (honda-tech, cb7-t) suggest that it could either be a
-vaccum leak, (unlikely)
-fuel system malfunction checked resistor box ohms and they are within range, checked injector resistance and they all between 2.6 and 2.7, this may or may not be an issue, ohms should be between 1.5-2.5
-EGR valve
could be but again unlikely
ignition timing- unlikely because i set it and check it myself and it is between 16 and 18 degrees BTDC because i run 89 and sometimes 93 but i could try backing it down and see if that works.
fuel filter clogged- unlikely but possible, I changed it about 2 years ago and dont think it would be f'd up so soon
spark plugs fouled- checked them all and they all look identical with brownish color and no build-up no white spots, and no corrosion
Oxygen sensor faulty- not too sure, I unpluged it and drove around with it unplugged and plroblem persists so i dont think it is faulty O2 reading considering the ECU was in open loop correct?? no signal means open loop fuel map right??
so this is all i have in front of me, I dont have too much knowledge of this being a common fault for CB7s or not but just try to bounce some ideas off of me, It idles fine. it pulls hard but between 1500 and 2500-3000 RPM it stumbles under load. just so annoying lol
-sean
-EGR valve
could be but again unlikelyignition timing- unlikely because i set it and check it myself and it is between 16 and 18 degrees BTDC because i run 89 and sometimes 93 but i could try backing it down and see if that works.
-sean
