Drain your oil without tools
    I saw this and thought i would share as it would make for an interesting topic of discussion. (not sure if this belongs under technical but ill move it if need be)
    http://www.qwikvalve.com/F-106-14mm-1.5.html
    ( home page if you have browser cookies disabled) www.qwikvalve.com
    These are my personal views VVVVVVVVVV
    Pros:
    *No tools needed
    *No more trips to honda for crush washers ( after 20+ oil changes its paid for itself )
    *No more stripped oil pan threads ( for the little kiddies or women that DIY while you are working away from home )
    *INEXPENSIVE !!!
    *NON corrosive metals
    "The Engine Oil Drain Valve has been tested and granted "Genuine Part" status by six major motor vehicle manufacturers in Japan"
    Cons:
    *No more magnetic bolt
    *I dont see how dirty particles would completely drain without a completely open path. ( wouldnt it get clogged in the valve and then the valve would become useless?? )
    *N-Series valve (with nipple to accept hose) is not recommended for passenger cars with low clearance."
    8th gen civic oil change http://www.8thcivic.com/forums/engin...alve-pics.html
    [COLOR="Magenta"]
    looks like a good idea, but i wonder if with time does it get cloged.
    AT WEST COAST MEET
    cb7rush: who has the tongs?
    JDMxDB8: i got a thong on...
    to get to see more of my cb click the link below.
    http://www.cb7tuner.com/vbb/showthread.php?t=130922
      i have a feeling that would get completely ripped off even if your car isnt that low.
      COUPE K24
        seems cool but i also wonder about it opening and all that nasty sludge and build up and or particles comin out fully
        ^^MY OLD RIDE
        http://www.cb7tuner.com/vbb/showthre...91#post3052591 <<**CURRENT DA9 BUILD**
          im concerned about this also. i guess it would have to be taken off and cleaned depending on how dirty your engine is. ( 5-10 changes depending )
          also it depends on which style you get. i would not get the elbowed ( L - Type style )
          most only stick out 1/2" longer than oem bolts + on the cb7 chassis you would most likely hit the front xmember brace and headers b4 your oil pan.
          slammed g37 members have used them 6 months no issues ( ie.
          [COLOR="Magenta"]
            I don't like it, looks like a solution looking for a problem.
            1997 Honda Accord EX-V6:
            Originally posted by James Matteu
            You have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
              thats very true i like that sentence right there.
              AT WEST COAST MEET
                x2
                '93 Bordeaux Red Pearl LX 5MT
                Prev CBs:
                -'93 BRP LX 4AT
                -'92 AGP LX 5MT
                -'93 AGP EX 4AT
                10yrs after my first cb, I'm still driving one!
                  I might have to get one and try it out
                  92 cb7 http://www.cb7tuner.com/vbb/showthread.php?t=176886
                  91 cb9 wagon
                    You still have to go under the car and take off oil filter anyway.
                      The only worthwhile upside I see here is not having to worry about getting splashed by hot oil. Then again, the filter is what usually gets me.
                      Crush washers only cost like 5¢ each from Honda. If you buy 50 or so from the parts counter, they usually cut you a deal. Hell, I've gone into multiple dealers and asked for dozens at a time. They've given them to me for free on numerous occasions.
                      The drain plug shouldn't be a hassle to remove. It's a delicate bolt and should never be tightened with anything more than an open-ended wrench. If you strip it, you know you've done something wrong.
                      True that!
                      My pictures/photos will return soon...
                        fram makes a better one and it even has a cap for the nozzle.
                          True that!
                          Yea the filer always got me....i did it so much on my cb that i had it down to a science but that friggin filter would splash me all the time haha!
                            1 Crush washer here at my dealership cost about 90 cents.
                            Yes my name is Dang, Don't use in vain
                            1992 Honda Accord EX (Coupe/Bordeaux/Auto)
                            1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
                            2008 Honda Accord EXL (Coupe/SanMarino/6spd)
                              That's steep! I've never seen them priced that high.
                              I just looked at an old invoice from a local dealer, I bought 5 at 11¢ each.
