Im having a prob with my trans shifting sometimes someday it works good sandsome days it wont down shift . when i stop at the light i have to turn the car off and crank it back up so it will move and shift. If im coasting at 55mph it will jump back in high gear. I have to pull over and cut it off wait a min start over .I change the tcu ,then I drain and refill fluid and clean the shift modules on the outside of the transmission .I still have the problem but not as bad as before. what do i need to look into next to stop this prob in it;s tracks.
at trans shifting problems
