im not sure if this is the place to ask this ...but remove it if you wish .
im planning on fitting a after market oil pressure gauge 2 a h22a since the warning in the cluster is busted . turn the ignition no light ..ive got the kit,but no place to put the aftermarket sensor ..i was thinking can i just fit the wire to the oem sensor then connect to gauge ? is this ok to do ?
