car surges 1k-3k all day everyday. read the stickies and did it all. cleaned the iacv with brake clean, bleed the coolant 3 times. i have noticed that if you have the intake off, theres a little hole in the tb and if you cover that up, it stops and idles like it should. whats the problem?
idle problems
mine did the same exact thing and i did the same things you did, on mine all that was wrong was a missing screw on back of throttle body plugged it with finger and it went normal just had to buy a new screwOriginally posted by '93CB7Ex View Postcar surges 1k-3k all day everyday. read the stickies and did it all. cleaned the iacv with brake clean, bleed the coolant 3 times. i have noticed that if you have the intake off, theres a little hole in the tb and if you cover that up, it stops and idles like it should. whats the problem?
Originally posted by TypeG View Postsometimes cleaning the IAC or others aren't enough and you have to replace them.
check the fast idle valve. take the top cover off and look inside. there's a white thing in there that come unscrewed and can cause that. later.
Wheres it at though? I have one on the DS upper. i took the top off and it just had a spring and a black boot thing. no white thing to turn.COUPE K24
ive done this on my h, along with cleaning the iac and bleeding the coolant. still bounces from 7-1600 all day. any other suggestions?Originally posted by TypeG View Postsometimes cleaning the IAC or others aren't enough and you have to replace them.
another possibility is the Throttle Position Sensor. My car is bouncing 1100-1900rpm, even with my IACV cleaned and FITV replaced. When my friend unplugged the TPS though, it idled high, but it idled smoothly. I have bought a new TPS and will be installing it saturday night hopefully, and crossing my fingers that solves the issue. You can pick up new TPS' off eBay for ~$19, i got mine from this seller called chandler motorsports or something.
