squealing belts after changing them??
    so i changed the ac/alt belt and now there squealing for about 1 min after i turn the car on. how tight should the belt be? i tried tightening it and loosening it but still did fix it. or what can it be?
    I have the same problem, but mine only lasts a few seconds.
    Members Ride Thread: LX ~ EX ~ For Sale Thread
    Sold to: accord=inspire? ~ Accord214 ~ Raf99 ~ daheavyking ~ OHOYAMA ~ JunyAccord ~ CBsevenTUNER
    Bought from: Joshy ~ TypeG ~ agol ~ 92smokeaccord ~ Extacee ~ mak ~ lindiz ~ illestatus ~ F20A CB7 ~ accord=inspire? ~ marcusv8thunder
      im starting to think its the pulley on the alt idk im goin to wd40 it just to see what would happen
        tighten it or spray some wd40 on it. should fix it.
        -Will
          probably needs more tightening, you should only be able to twist the belt with your fingers about 90 degrees or it should only deflect 1/2" when on the pulleys, if you can do it more than that then its too lose and needs to be tightened.
            would wd40 harm the belts at all, if they got splashed on accident? my sister's car has a squeak i'm pretty sure is a pulley, i just cant identify which one so i thought i'd just spray some lube on each one in turn. didnt think about belt tension though, i'll have her swing by again.
            Accord Aero-R
