would this be true for the automatic tranns to?
i'm experiencing the same symptoms. first thing i notice was the sport light was on. so i took it as the tcu was acting up, like it always does when the outside temps get warmer. car started fine. once put in gear the rpm drop, then eventually the engine stops.
checked for codes. solid S and check engine light was on also. trans fluid seems fine after checking it.
thanks
Originally posted by HondaFan81
View Post
thanks
