Bisi header rear bracket
    Anybody find the oem rear downpipe bracket impossible to install on the bisi header? Mine's bolted up fine, slipped on to where there's an even 3/8" gap between downpipe and oil pan. I had to flip the bracket backwards and edgeways and bend part of the flange to bolt it up, and it's only bolted with one bolt instead of two....???
    My Member's Ride Thread
    I ended up using a DX/LX bracket, EX/SE will not work IIRC, had to flip the bracket around backwards and bend it the opposite way for a good block to bracket angle. I think I got all my nuts and bolts in, this was awhile ago.
      Yeah I had to do sorta the same thing. I was only able to get one bolt in the block and one on the header though. I may end up buying some mild steel and making my own bracket.
        looking for a bracket as well. Still just having problems connecting top half to lower half
