I have an occasional bouncing idle. It seems to be occurring more frequently.
My FITV and base idle have already been set, and I just double checked the FITV.
I've cleaned out my IAC.
I've read these two helpful threads, and will be doing some of the second one tomorrow.
http://www.cb7tuner.com/vbb/showpost...33&postcount=1
http://www.cb7tuner.com/vbb/showthre...highlight=fitv
I'm hearing a whistling, which is making me think I have a vacuum leak. The whistling is more pronounced when my fans turn on.
Just now, when I was searching for decaying vacuum lines, when I was to tap the throttle from under the hood, the idle would bounce. After a few minutes, it would stop.
One last thing, and this is what really has me concerned:
Today after getting gas (idle still jumping), I was driving back home, and I noticed my revs weren't falling like they should. I.E. I was idling along at whatever speed I stopped accelerating at. So, if I was to let off the gas at 50, it would stay at 50. Kind of like an automatic cruise control. Other then the above symptom, the idle issues stop when in gear.
Any guesses as to what I should do?
Tomorrow I'm going to(In order):
1. Starter fluid around my vacuum lines to see if they're the issue
(replace all if I find one)
2. Clean out intake(TB) with cleaning fluid
3. Replace FITV with one of the extras I have
Not really sure what to do after that. I'll poke around with the second linked thread. I guess I could clean the IAC again.
Would a dirty air filter cause this? I have a K&N drop in. It hasn't been the recommended 50k cleaning period yet, but I was planning on doing it this summer anyway.
What size vacuum lines do we have? Anything bad about buying a bunch from Autozone? How many feet is there?
Any help is appreciated, especially if you read that whole thing.
Edit: The whistling isn't immediate. I can hear a sucking sound at first, then it turns into a whistling. I think I might have mistaken that for my distributor in the past.
Also, if anybody wants, I can make a video.
Now I'm really looking forward to doing this after work
