so tonight i was driving home from my local meet, i got to the stopsign to merge, it was wet out, i semi-launched and spun first-second and then drove normally. i then got it to fifth, and gave some gas to pass someone, and the revs went up to 6 but i went nowhere(mind you, the road was soaked,) and i started to smell a burning smell. i babyed my car home, and took it around the block where the road was much dryer, no slipping or burning smell. it only happened on the highway that one time. could my clutch be gone? it grabs normally and doesnt slip when i get on it at all...any help would be appreciated
oh and its a f trans open diff
Clutch effort is not much greater than OEM, so you won't have an overly toned left calf. DDing takes a bit more work though since the flywheel is much lighter than stock, 22lbs vs 8lb makes taking off initially a bit harder.
