Looking for Honda Technicians and experienced mechanics input here!
All input is appreciated as well.
Just re-ran the compression test on my gf's JDM F22B DOHC, results were not inspiring.
CYL #---Dry---Wet
Cyl#1---120---185
Cyl#2---180---210
Cyl#3---190---210
Cyl#4----90----95
Results measured in PSI.
What am I looking at for engine work? Rings I dont think I need, maybe on cyl 1. Valve seals, or bent valves?
Guy I bought the car from (engine came in a 92 Accord) said that he had the head redone at 40K miles, head was replaced with a F20A DOHC head due to cracking the original. Head is a PT2 casting however, and much cleaner than the block, like brand new inside, so seems to confirm his story. Timing is dead on.
Please tell me its going to something easy like popping the head off and replacing valves.
CYL #---Dry---Wet
Cyl#1---120---185
Cyl#2---180---210
Cyl#3---190---210
Cyl#4----90----95
Also was running a PT3 ecu. It was all sorts of fail.
