a/c problem
    a/c problem
    well guys, im working on a 91 cb, and compressor wont engage by it self, when 12v is applied to compressor and i turn the fans on, everything works, pressures are perfect, temps are great, but it wont do it on its own
    things i've checked:
    thermoswitch works
    dual pressure works
    both relays work
    clutch works
    a/c light turns on
    replaced diode with 2 other
    the only thing that gave me hope was, i put ground to the blue/black wire that goes to the A/C diode and BAM, idle goes up, compressor engages, fans turn on
    but if i try to drive with it, it will blow the a/c fuse in the dash fusebox
    i need some help guys
    thanks
    Just do what PR CB7 said.
    Have you checked the HVAC control switch and the wiring from there to the relay? If everything past the relay works, the problem must be before that.
