View Post
Fuel pump or Main Relay? No Fuel to the Motor
when you solder the relay it is very easy to bridge 2 terminals that short can fry the whole chip and relay. I had an issue with mine about a year ago I went to a mechanic to do the fuel pump and a week later my car would not start so that i found the tutorial online to solder the relay and no issues since.Originally posted by GummiegorillaDamn CBs are like a Rubix Cube sometimes !!!!
Originally posted by pedalpusher90 View Postwhen you solder the relay it is very easy to bridge 2 terminals that short can fry the whole chip and relay. I had an issue with mine about a year ago I went to a mechanic to do the fuel pump and a week later my car would not start so that i found the tutorial online to solder the relay and no issues since.
Go to the junk yard and grab a few more relays, this SOOOOOOO sounds like a bad relay.
I have a Haynes manual for a DA Integra and it has a WONDERFUL step by step process to determine a no starting issue. I actually ended up with a bad ECU after a motor replacement. The Haynes manual for the CB7 does not seem to have this same awesome flowchart so its a bit more difficult for us to diagnose. I still lean towards the main relay, usually its the simplest thing causing the problem.
Originally posted by Noridetoolow View PostGo to the junk yard and grab a few more relays, this SOOOOOOO sounds like a bad relay.
Originally posted by brian91accord View PostSo now when i changed the relay i have no fuel or spark. This is 2 new relays i have in my hand. My coil is getting power. My pump reads power when i jump 5 & 7. When i don't jump it the pump has no power. I took the ground off of the thermostat and the CEL turns off..
So if your checking for power, you need to do it while turning the key on . . .
Have you checked for any codes?
My 5.7 LS1 Holden Ute
Originally posted by evil_demon_01 View PostYou do realize that the pump only turns on for a few seconds when you turn the key on right?
