Check engine light came on and throwing codes 6,14, which are a IAC Valve and a Coolant temp. sensor. My readings for the IAC are 12.7 ohms at the valve and 11.27V at the plug which are in line with the haynes manual. Coolant temp. sensor is reading 208 ohms in running conditions, 1287 ohms when cool and 5V at the plug. I just replaced this sensor a few months ago. Recomended setting in manual is 280-350 when running and 2200-2700 when cool. I was wondering if anyone out there might think it is indeed the sensor since i just replaced it not to long ago. If not is there anything else i can check. Thanks
throwing code 6 and 14
Bump I have the same issue2013 Honda Fit Sport Alabaster Silver Metallic GE8
2013 Accord Sport Modern Steel Metallic CR2
CB9 http://www.cb7tuner.com/vbb/showthre...hlight=hostile
CR2 http://www.cb7tuner.com/vbb/showthread.php?t=197787
GE8 http://www.cb7tuner.com/vbb/showthread.php?t=199289
