burning oil fix
    burning oil fix
    Hey guys. I've got a stockish f22 that's been burning oil at WOT. I can see the smoke in the rear view mirror when I get on it. And its got the dreaded black haze on the rear bumper. Is this something that can be fixed with a valve adjustment or something. I'm loosing enough oil that I have to put in a quart after 2500 miles. Motor has 210000 miles. Thanks in advace.
    MY MEMBERS RIDE THREAD
    bump... i got the same on my jdm h22....but i dont burn that much oil....
      depends where the oil is comming from.
      Check the Intake manifold and the pcv hose for signs of oil. Then pull the spark plugs and look for oil on the plugs. If it isn't that then you should do a compression/leakdown test. With those results you should have a good idea of what is happening.
      With all that said my guess is rings, since you mentioned wot in your post I'm betting it gets beat on a bit.
      201 Whp H22a with bolt ons, see the progress from stock f22a to now HERE
        rings would allow that much consumption
          valve guides maybe gone
          (129)Transactions and counting
            Check your spark plugs first since its the cheapest. Then, you can do a compression test to see which cylinder(s) it's coming from since it sounds like the piston rings. Or you can always do a leakdown test to see whether the problem is coming from the head or block. If its the head probably worn valve guides and if its the block more than likely bad piston rings.
              how do you do a leak down test. i still haven't gotten around to checking anything yet but just in case i gotta do it, id like to know how.
