So I'm in the middle of an engine rebuild and just got done putting my crankshaft on the block. Now I'm having trouble putting the piston rings on the piston, specifically the oil ring. I was wondering is there any kind of trick to putting on the piston rings? They're P13 pistons for a H22a1
Any special trick to installing piston rings?
Yeah that was actually the exact diagram I was using when I was putting them on. I don't think I was suppose to put the crankshaft on the block yet cause I'm having trouble getting the rings past the cylinders cause I'm trying to put the pistons and rods in now. Someone told me to put the crankshaft on first then the pistons, but I'm going to try putting the pistons and rods in first then the crankshaft. Thanks though for the reply
Crankshaft does go in before pistons and rods. Removing the crank will not allow you rto get the rings passed the deck surface. You need to buy/borrow a piston ring compressor. This is used to compress the rings while you slide the pistons into the cylinders.
Also, make sure that you remove the rod caps and cover the rod bolts with a rubber cap/piece of hose. This will keep them from scratching the cylinder wall or crank journals as you are installing them.
You should have a helms manual for a prelude (H22A) on hand before you put this back together. It has a step buy step for installing the crank, rods and pistons.Last edited by GhostAccord; 02-18-2012, 06:23 PM.
Yeah I've been using this Chilton manual its for preludes and accords, but ended up buying a ring compressor and was able to get the pistons in the block. Ended up leaving the crank on like you said too, I don't know why I thought about taking it off and trying to put the pistons & rods in without it. Guess I was just trying to figure it out myself, but seems it's best if you just follow the manual.
Ladies and gentlemen! We have a winner!Originally posted by Restless View PostYeah I've been using this Chilton manual its for preludes and accords, but ended up buying a ring compressor and was able to get the pistons in the block. Ended up leaving the crank on like you said too, I don't know why I thought about taking it off and trying to put the pistons & rods in without it. Guess I was just trying to figure it out myself, but seems it's best if you just follow the manual.
