car wont idle down past 1500...did all the checks not really done yet but anyone else have anything similar?
idle problem
idle problem
Ride List
1990 Accord dx coupe - my baby (dsm turbo set up in progress)
http://www.cardomain.com/ride/3202853
2005 Mazda 6s - daily driver http://www.cardomain.com/ride/3171724(totaled
newest 2006 mazdaspeed 6
http://www.cardomain.com/ride/4073987/2006-mazda-mazda6Tags: None
set base idle(look in sticky on beginners)Originally posted by blazenem View Postcar wont idle down past 1500...did all the checks not really done yet but anyone else have anything similar?
make sure throttle cable isnt to tight
clean iacv(idle air control valve)
check your fitv(cant remember what it stands for lol)
make sure the spring on your pedal isnt worn out
I'm having the same problem on my H22..I already swapped in 3 different FIVs and IACs with no cure. I'm thinking it might be my intake manifold gasket that its leaking from.
I've got an older model Hondata (white color) so it may be cracked since it is made out of that thicker plastic, thereby letting air in. I'm going to take apart the intake mani one of these days and find out if my assumption is correct.
would a lightened flywheel affect the idle like this/ i feel like its a no but i never had a car with one so i wouldnt know. and i will do all those checks
Ride List
im thinking the same thing i hope not though...i just changed mine on my old motor but that one blew up lol. hey your in az lets have a manifold gasket swap party at my house lolOriginally posted by Losiracer2 View PostI'm having the same problem on my H22..I already swapped in 3 different FIVs and IACs with no cure. I'm thinking it might be my intake manifold gasket that its leaking from.
Ride List
yeah I need to order a new Hondata one most likely. I can't remember how long ago they changed over from the white plastic to the blue lolOriginally posted by blazenem View Postim thinking the same thing i hope not though...i just changed mine on my old motor but that one blew up lol. hey your in az lets have a manifold gasket swap party at my house lol
ha took me 5 mins to fix it after spraying water all over the intake and vacuum hoses. i said to me self, "self, did you check the throttle cable?" my self said " no i didnt let me check that now.." so i pushed on the throttle cable assembly on the throttle body and low and behold the idle dropped. so now car idles at a steady 850 to 900 rpm. Phew crisis averted, i am glad its not the intake gasket..
Ride List
