i pick up a h23 head and intake mani for $50 today and was wondering if its really worth it to swap the head ??, i just wanted the intake mani but the guy would not part it so i agreed to take the head also cause i figured it was a good deal
h23 head or f22 head ?
Honestly for $50 there is probably something wrong with it. I would have it checked out by a machine shop before you get into swapping the head. In the mean time, do what you were going to do with the H23 intake manifold.
You own the head now so you can do whatever you want with it. It would be a gain if you are looking to do some cam tuning while using aftermarket cams. As having the individual intake and exhaust cams can make it easier to change valve timing events. That will help with overlap and exhaust scavenging. Where as the SOHC requires the cam profiles to be changed in order to get different intake and exhaust lobe separations and valve timing results.Last edited by GhostAccord; 03-19-2012, 11:41 PM.
yea the head have bent valves he said, i am planing to buy a bisi stage 2 cam for the f22 head and getting that head ported, would i get better results with the h23 head or the same if i do the same to the h23 head ?Originally posted by GhostAccord View PostHonestly for $50 there is probably something wrong with it. I would have it checked out by a machine shop before you get into swapping the head. In the mean time, do what you were going to do with the H23 intake manifold.
You own the head now so you can do whatever you want with it. It would be a gain if you are looking to do some cam tuning while using aftermarket cams. As having the individual cams can help with valve timing events that will help with exhaust scavenging. Where as the SOHC requires the cam profiles to be changed in order to get different lobe separation timing results.
Stick with the F22 headOriginally posted by ryanjones45 View Postyea the head have bent valves he said, i am planing to buy a bisi stage 2 cam for the f22 head and getting that head ported, would i get better results with the h23 head or the same if i do the same to the h23 head ?
For reasons as linked above. Also bent valves could actually mean more work required than just the valves being replaced. Could also mean guides, seats and rocker arms..etc..etc...
