Hey everyone!!! so after researching 5 full pages of "trans noise" via the search bar. i have found no thread directly influenced by my particular problem.
car info: 1992 dx, f22a1, stock manual 5spd transmission/clutch etc, nuespeed "short shift adapter", other than suspension mods, short ram, and a full "gutting"" minus hvac and dash", car is stock.
1st: i have a noise coming from the front right of my engine bay similar to morse code, an indirect, low frequency intermittant beeping, directly above and or around the tranny, not really prevalent from the front right wheel well, but almost directly above the trans.
2nd: this noise only occurs when the car is at normal operating temperature.
3rd: this noise NEVER happens when i am moving. i.e. driving, stopping etc...
4th: this noise only happens when the car is at a stop.
5th: whether i have the clutch engaged or not, car in gear but NOT moving the noise still persists.
6th: the only factor that affects the noise is the brake pedal!!! i.e. brake pedal engaged = no noise, brake pedal disengaged = noise. etc
7th: oddly enough, the noise "stopping" tends to alternate between which position the brake pedal is in, i.e. brake pedal engaged = noise, brake pedal disengaged = no noise.
8th: i should also add that i have zero issues up shifting, driving, dowshifting, clutch engaging etc....
I really have no idea what that could be, considering that the brake pedal constitutes whether or not the noise happens.
let us ponder a formidable solution!!!!
