For some reason my sidemarkers and corner lights turn on when my brake is pressed. The dash lights also come on. When the car is turned off and I press my brake the "Lights left on" indicator sounds off. Anyone know what can be the problem?? Its getting very annoying.
Edit...Possibly A bad ground?? I have the headlight harness directly connected to the HID module. (Didn't cut or anything, only de-pinned).
Also I have the Fogs always on mod done to it done with this DIY.
http://www.cb7tuner.com/vbb/showthread.php?t=158593
Ive disconnected the HIDs, still does the same ish. Disconnected the ground from the Fog DIY, same ish.
Edit #2...Weird. If Parking lights are on it allows to me shift the gear without pushing the brake in. If off doesnt allow me to. Theres a Click sound that come from the shifting module when pushing the brake and when I turn the lights on.
