Driver side power window problem
    Good day everyone! I just went out to roll up my driver's side window and noticed that the window seems off track from the window run channel. It also started to slow down then speed back up half way during roll up, similar to something binding it. The motor still works and I don't hear any crunching so I'm guessing the motor and regulator assembly is good (previously replaced by past owners).
    Thanks to ETCG, my guess leads me to this:
    Does this sound about right or has anyone else experienced this problem?
    I snapped a couple quick photos:
    You answered your own question Usual problem with our cars, you can try and adjust and lube up the channel to fix it or do what ETCG did. I find myself lubing my a lot in the summertime, as it will start to slow/drag when it gets dry. Best of luck
      Thanks! I'm going to replace both front window run channels since the passenger side is kinda kinked/loose around the mirror area.
      Good time to replace my speakers too!
      Also, how far down do I need to roll the window to access the glass to regulator bolts and what's the best way to realign the window after replacement? Pics would help greatly!
      Thanks!
