I just got done rebuilding my engine and i'm more than 1/2 done, but I might have messed up on the oil pump installation. When I installed it, I forgot to put in all the bolts.
The relevance of this is the liquid gasket I applied when I first put the pump on. The manual says to put the pump on not more than 20 minutes after you apply the liquid gasket. It specifically says, "Do not install the parts if 20 minutes or more have elapsed since applying liquid gasket. Instead, reapply liquid gasket after removing the old residue."
It was 20 minutes or more after I completely put it on with all the bolts. Has anyone ever done this and do you think I can just leave it as it is?
When I first put the oil pump it seemed to be sealing fine even with 4 missing bolts. I just forgot to put in all of the bolts until I got done with the water pump which was over 20 minutes later.
