On an estimated cost, how much will it be to convert my auto to a 5spd? Is it worth it or should I just try to trade and get an accord that already has standard transmission?
Auto to 5spd conversion
The subjective questions with many unknown variables are always the most fun.
What's your mechanic ability?
What tools do you have or have access to?
What is your workspace like?
How long can the car realistically be down?
Do you have access to the parts you'll need locally? Shipping a transmission is not cheap.
Have you looked around at the price of a comparable car to have a control to compare your pricing and effort to?
Considering all that, a transmission will be around $100-250, you'll need a clutch, flywheel and throw-out bearing for about $200-300, clutch slave and master for about $50 and pedal assembly, lines and other hardware can come from the junkyard. If you haven't read the DIY on here then shame on you for being lazy. Make up your own mind as to whether you should or shouldn't.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
You shouldn't mess with an auto if you are planning to floor it at times. The automatic tranny won't hold that kind of abuse. You'd most likely want a 5 speed and rebuild it.
I WAS in the same position as you are and decided not to do the swap. Why? I don't know, I mean is it really worth it? Just sell her and get a original 5 speed. Less hassle, and you'll be happier you did in the end.
for me? these are the prices I paid:
ESP Auto to 5spd mounts: 275 shipped
Exedy Stage 1 clutch: 260 shipped
Fidanza 8lb flywheel: 155 shipped
Used M2A4 tranny: 100 picked up (bad idea, fell apart 8 months later), about
650 for LSD tranny I got later on in Anaheim, CA from
importer
5spd swap parts bought off member: 140 shipped (pedals, prelude shifter,
Clutch master cylinder, hardlines, slave cylinder)
labor to do swap: 500
Misc: 50 bucks (MTF, cleaning supplies, paper towels, gloves, fast food lol)
So total I spent: About 1500 bucks initially to get the car running and it lasted me quite awhile, until I got fed up with my worn out tranny i got off craigslist. (grinding/popping out third gear and shot bearings)
I later got an M2B4 LSD tranny...decided to splurge so that cost me 650
But after recently doing my own tranny removal and install (April 12') in order to replace the 5th gear, syncro sleeve and bearings, I say you can save the 500 I spent on labor and do it yourself in about a weekend...all it is is monkey labor, nothing complicated at all.
So budget approx 1000 I would sayLast edited by Losiracer2; 10-16-2012, 10:51 PM.
member's ride thread
91 Accord SE 176k
I beat the shit out of my auto tranny for 7 years before I swapped to 5 spd. It probly could have gone another 7 years. I'm not saying they are bomb proof but the occasional flooring did no harm to mine.Originally posted by Vex View PostYou shouldn't mess with an auto if you are planning to floor it at times. The automatic tranny won't hold that kind of abuse. You'd most likely want a 5 speed and rebuild it.
I did my 5spd swap while I had my motor out so it made it much easier. I wouldnt have done it with the motor still in. Not enough room to work and im lazy as crap.
With the motor and everything out of the bay I could stand in there and run the cables, clutch line, etc.
Easiest way to do the line from the master cylinder to the slave is a single steel braided hose, eliminating brackets, the damper, uneeded crap in the bay.
