ok i was on my way to go get some cat food today and i take a turn and theres no power its like a 250lb guy sits on a 40cc 3wheeler thats what its like idk what happend and now theres oil in cyl 2 plug wire spot i need some help here
Zero Power
ok you are leaking oil in the on to the spark plug . replace all spark plug tube seals and valve cover gasket . you can bye a kit at honda for cheap . dont try auto zone or oriellys they will not fit properly and you wil be doing this again soon . then you need to do a full tune up . is what more than likely happen is the oil foul the plugs out . this has happen to me i went through spark plugs like crazy until oil leak was fixed.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
CEL= Check Engine LightOriginally posted by 92a6 View Postno its not on and it had a idle issue and it just fixed itself when it lost power not sure why
MRTvvv
