locks
    locks
    So car got stolen, need to replace all the locks and i cant find a write up anywhere for the life of me.
    door locks, trunk lock, and ignition lock
    Have you ever considered calling a locksmith for price quote for the work?
    A&P-IA
      no, i do all my own car work provided i can, and im sure it will be time consuming but it cant be THAT hard, im sure the only one ill really need a guide for is the ignition lock, the other look pretty strait forward.
        This might give you some idea.
        http://www.youtube.com/watch?v=EisqrhScvKQ
        A&P-IA
          ive changed mine 2 times lol. its easy. ignition is the hardest one. then the door locks. that little clip is laaaaaaaame.
          COUPE K24
            figured it would be that way, thanks for video that should make ignition easier
              Why do you need to replace the locks, did they steal your key as well?
              My 5.7 LS1 Holden Ute
                no they jacked up my drivers door lock really bad(like i opened it with my forklift key), and they didnt hot wire it or anything, so they must have had a key that was close for ignition, and since its older and wearing down why not replace them all with a new set, its only 124$
                  for anybody that finds this thread the ignition one is "challenging" there will be a pin that u need to press down thats kind of under the windshield washer arm thingy(cant think of name lol) then there is also a set screw next to that, that needs to be un-done, you will have to use a pair of vice-grips or something along those lines, even if you take the washer arm thingy off you cant get it with a screw driver.
                  the doors and trunk were easy though
                    If I lived in a crime area like you, I would purchase an alarm, put some rear handles on the front(no locks, thiefs would be shocked,lol), and hide a kill switch somewhere. Kill switch most important, can`t steal it if you can`t start it.
                    Project:Black Skittle
                    AOM->April 2014
                    MRT->http://www.cb7tuner.com/vbb/showthread.php?t=199779
                      getting a viper 5704 2 way pager system installed and im going to put a kill switch in it
