What Does This Cut Wire Attach To?
    After taking out my radiator, I noticed a wire hanging. It was in the loom right next to the radiator fan wire on the driver side. Where does the supply power to or from?
    The Lord watches over me!
    - D. Chappelle
    It goes to the ac compressor, for the clutch
      Very correct you are. I may have gotten snagged during radiator removal/replacement. Shit!
      Now I have to either get a new AC compressor, or take this one apart and rewire it. The wire came all of the way out of the compressor. I knew there was another male/female connector present when removing the radiator.
      More work to do now.
      - D. Chappelle
        Take it apart if you can, Once you get the pulley off you should be able to see if you can reattach it to the coil.
        If it's pulled it right out of the coil, either get a new coil or whole compressor.
        My 5.7 LS1 Holden Ute
          My first solution would be to replace the coil if possible. I'll take it out with the motor, and see if I can fix it.
          - D. Chappelle
