I got this problem now with my automatic transmission. It seems like its slipping when going from 1st to 2nd, its like its in neutral and it can't find the right gears. The speedometer is not working either. I pulled the codes and it listed a code 4, which is a speed sensor, and a code 15. Code 15 concerns me a lot. Code 15 15-Kick down switch circuit shorted.
Both of these problems started happening after I drove on the highway. Specifically it was after I downshifted to pass a semi that was in the right lane. It was at 4,000 rpms at about 55 mph. Now my transmission is acting bad.
It doesn't slip all the time it just seems to whenever the speedometer stops working.
Please help, I need to fix this. I don't know if the transmission is bad or what.
List of codes,
0-Transmission control unit (TCU) faulty.
1-Lock-up solenoid 'A' circuit open or shorted.
2-Lock-up solenoid 'B' circuit open or shorted.
3-Throttle Position Sensor circuit open or shorted.
4-Vehicle Speed Sensor open or shorted - No signal from speedometer.
5-Shift Lever Position Switch circuit shorted.
6-Shift Lever Position Switch circuit open.
7-Shift Solenoid 'A' circuit open or shorted.
8-Shift Solenoid 'B' circuit open or shorted.
9-Counter shaft or transmission speed pulse generator open or shorted.
10-Coolant Temperature Sensor open or shorted.
11-Engine RPM (Ignition coil signal) open or shorted.
12-(No code 12 used)
13-Main shaft speed pulse generator open or shorted.
14-Linear (line pressure control) solenoid open or shorted.
List of codes,
