Front Brake Knocking Sound
    Hey guys,
    I just replaced my front rotors and brake pads last week and now when I apply the brakes, I hear a 'knocking' sound every now and then. When I apply the brakes a bit harder, the knocking sound is louder. The sound is relative to the amount of pressure I'm applying the brakes at.
    Rotors: Brembo Ventilated Discs
    Pads: Hawk HPS Pads
    Any ideas?
    Make sure everything is tight.
    I've had it once where the rotors loosened themselves.
    I was on vacation. Luckily, they did it after I arrived, and not on the 250 mile journey.
    MRT
    sneaky motherfucker
      Make sure everything is properly torqued. Grease the caliper pins. Pads are seated in the brackets. Calipers move freely. Piston not frozen. Correct matched parts.
      Good luck
      Kyle C
      2002 Accord Sedan EX - standard- daily status
      1991 Accord Wagon LX - auto - 304K & slipping transmission
        Thanks guys. I'll give it a try this weekend and let you know how it goes.
          tighten up those cv axle nuts that was my problem
            it sounds like its coming from the caliper brackets not being tightened down enough on the knuckle.
            Either way, stop driving immediately and get that fixed. You don't want to not have brakes when you need them.
              This... It happened to me last summer on my other Accord. I finished a brake job and thought I torqued everything down. I missed one bolt on my caliper bracket. It would make a clunking sound everytime the brakes were applied. It was the Caliper and the Bracket banging into my rotor from the missing nut.
              You will want to check the rotor out on the side it is doing it on also.
              My MRT
              White Devil Owned by Axle
              Go Fast or Suck
                So what did you find out?
                Thanks.
                  It could be the strut rod bearing(radius rod bushing) whatever the hell its called
                  steve
                    I took it to the shop to have it looked at and the mechanic just tightened up all the bolts and nuts regarding the brake components. No charge! After that the brakes worked fine.
                    Before the tightening, my brakes felt loose. I could press down on the brake pedal and feel not a whole lot of resistance. But after re-tightening, the brake pedal now feels a lot tighter and no more knocking noise that goes with it!
                    Thanks everyone for your helpful replies.
