Intake manifold removal.
    My car is a 1990 LX 4AT. I want to take the intake manifold off to replace the rear mount and clean out pretty good. I need some advice on what else, gaskets wise and parts replacements that I might need so I could prepare for it. Also, is coolant replacement needed and how much of it.
    Here's the diagram:
    I know I need gaskets #12, #14, and #18. Should I get one for the throttle body as well?
    How many bolts to take the manifold off? Perhaps some one could give a complete steps of what needs done as if you have done it already. I have the downloaded manual and it does not have a complete and clear procedure of doing this. It just has the head removal and engine removal. What are the torque specs so I won't snap and break any bolts.
    Thanks.
    Other than the gasket, do I need to use any thing else like RTV silicone in the corners like the valve cover?
    If I don't touch the TPS, I don't need to calibrate it after the installation?
    Thanks.
      No sealant needed.
      Just get the bolts nice and snug. They're not 10 mm so you can use a good amount of torque, not too much though.
      “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
      ― Jeremy Clarkson
        So what size bolts are they? 12mm? I read over the Hond-tech forums, the gasket is a bitch to clean up as you have to remove a few studs to put the new gasket on. At the same time, cleaning off both of the mating surface is a toughie.
        Thanks.
          Thanks.
          Theyre' 12mm man, and cleaning the surfaces is hard because the old gasket material gets very cooked on it and it takes a razor blade to remove it.
          ― Jeremy Clarkson
            Its probably a good idea to put some Hondabond or Permatex Ultra Grey around the coolant passage between the head and the intake manifold, but other than that it should be straight forward.
            Most things on our Honda's can be removed/replaced with a 10mm, 12mm, and 14mm wrench.
            If you don't have those wrenches, you don't deserve to be anywhere near an old Honda
              Originally posted by Mishakol129 View Post
              No sealant needed.
              Just to clarify on this post, because I don't want you snapping studs, the proper torque spec is 16 ft/lbs.
                Thanks. What size are the bolts? 12mm hex?
