Header installation (beginner)
    Greetings
    Im installing headers for the first time. Did some research first, pull oem header/dp apart, remove, install new one(with gaskets). AM header requires finangling around ac lines. Got it.
    I removed the heat shield, PB blasted everything, and finally got it up on jack stands.
    Now the 3 bolts for the stock header to downpipe, how to access the third bolt behind cross member piece? Pull everything else off first to gain some room?
    Ive seen different torque specs for tightening the bolts. Anyone have the definite specs? I dont have a manual.
    Also any other pointers for a novice would be greatly appreciated.
    You may want to use anti-seize on threads upon installation for ease of removal the next time.
    For proper torque, see below. Those numbers should be correct to your application.
    A&P-IA
      23lb for the top
      40lb for the downpipe
      Thanks man, I really appreciate it. I'm about to tighten up now.
      I wrecked one of the downpipe bolts so Im going to the store now to get a new bolt.
      Btw, my relatives live in lake worth, so next time Ill just come to your house for help, lol
      Thanks again man
        that's cool with me
        A&P-IA
          If only I had known that before, cool man, I might just take you up on that.
          Got some anti-sieze too
