Hey everyone. So my a/c compressor is making some howling noises and needs to be replaced. Currently the system is still on r-12 and blows decently cold, but I'm pretty sure it can blow colder, particularly when on fresh air. Here is my plan after safely removing the r-12:
1. Replace compressor (new denso united with new clutch)
2. Replace drier
3. Remove evaporator core, clean, and replace expansion valve
4. Pull a hard vacuum on the system to remove any moisture and make sure my repairs are good
5. Refill using either RedTek http://www.redtek.com/products_refr.html# or Envirosafe 12a industrial http://autorefrigerants.com/co00033.htm
Here is my question for people here, has anyone used either product and if so, how do you like it?
Also, RedTek says to charge into a "0" atmosphere system, but won't the outside air inside the system create problems and reduce cooling capacity?
2. Replace drier
