Hey tuners,
1) can the idle adjustment screw be neatly removed from the TB by turning the screw counter clock wise ?!
2) the screw is for idle adjustment depending on which way it turns, however my question what is practically taking place when turning the the screw, does the TB sucks air in or out of the Plenum ?!
I am asking because most silicon has been removed and when I adjust it to the value I want should I glue it back ... wouldn't that block the air flow through the screw ?!
