another bad tcu why.
Car safety checks
Fluid CapacitiesTags: None
These computers are over 20 years old man. They're gonna stop working A LOT. Especially if you're buying used ones. If you're buying new ones then they might just be poorly made. I know different cb's have different tcu's. SO maybe you're installing the wrong tcu each time.Last edited by emosun; 11-08-2013, 01:09 PM.
The best TCU is your hand!!!! 5spd FTW!!!!
All jokes aside. You're probably just getting a bunch of 20 year old fried TCUs. If they work for a while and go kaput, they're just expiring on you.'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
Originally posted by emosun View PostThese computers are over 20 years old man. They're gonna stop working A LOT. Especially if you're buying used ones. If you're buying new ones then they might just be poorly made. I know different cb's have different tcu's. SO maybe you're installing the wrong tcu each time.
Originally posted by Joey GT-R View PostThe best TCU is your hand!!!! 5spd FTW!!!!
All jokes aside. You're probably just getting a bunch of 20 year old fried TCUs. If they work for a while and go kaput, they're just expiring on you.Last edited by Accord problems; 11-08-2013, 01:42 PM.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Just rebild it. You can send it out for repair for around 150 $.
Open it and see what needs replacingWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Originally posted by accordztech View PostJust rebild it. You can send it out for repair for around 150 $.
Open it and see what needs replacingthis was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Originally posted by illinois_erik View Postmaybe the shift solenoids are bad and drawing too much, or gummed up etc. have you popped them off to clean the screens then you can bench test them for operation and coils continuity.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Ok i pulled of the shift solenoid . It was a little dirty not much . So i pulled the lock solenoid . It was a little dirty just like the othere one . I took it for a test drive and it was messing up big time . So i put the fork back in the diagnostic port and car ran fine .this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
