Ever since I got my 5-speed CB7 sedan, the oil pressure light has never worked. Anyone know what it could be, or what I can try for diagnosis? Thanks
Oil Pressure light doesnt work
What leads you to believe it doesn't work?My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
Originally posted by Jarrett View PostWhat leads you to believe it doesn't work?
I know that it doesn't work because when I turn the key to the "on" position, all the other lights come on except the oil light.
Also, when I start the car, it doesn't flicker like it should. Any help would be appreciated
I don't remember my car doing this, but I would start with the bulb. Try another bulb in it and see if it fixed the problem. More likely its the bulb than a wire/sensor issue on the engine side.Originally posted by blackack View PostI know that it doesn't work because when I turn the key to the "on" position, all the other lights come on except the oil light.
Originally posted by Raf99 View PostI don't remember my car doing this, but I would start with the bulb. Try another bulb in it and see if it fixed the problem. More likely its the bulb than a wire/sensor issue on the engine side.
It very well could be the bulb, the left turn signal light doesn't work either. It was infested with mice before I bought it. Dammit lol
