Evening ladies and gents,
I'm getting ready for another strip trip, and I want to get to the bottom of an idle drop on cold starts.
Right away, it will start up near 2k, and always has after the tune, which is fine for me. Recently, it will fall dramatically to below 500rpm pretty quickly, and if I don't lightly press on the throttle to keep things up, it will throw a code 9 for the CYP. As the car warms up to above 60deg. C, I can take my foot off the throttle. The idle struggles at around 800 or 850rpms and rises as things warm up to operating temp. The operating temp idle is 1050 rpms and was set by the tuner at Blacktrax. Having a code 9 has not affected at temp operations whatsoever, which makes me think the CYP circuit was shorted by the erratic idle. I also found cylinder 3's spark plug wire not fully fastened down, so I gave it a push in until I felt and heard that satisfying pop. I haven't driven it since then, so that could potentially make a difference at the next start up.
What is the Innovate MTX-L saying about AFR's throughout all of this?
1. As soon as the display begins reading, there is a subtle bump in the amount of fuel being supplied per ECU instructions, which makes sense. I take my foot off, at this point, and as the idle drops, the AFR's rise to around 20 to 22.4.
2. The coolant is just above 60deg. C now, and the AFR's will read in the high 17's and low 18's when my foot is off and the idle has risen to the stuggling ~825rpms.
3. The coolant is between 90 and 92deg. C, and the idle is at ~1050rpms, and the AFR's read in the 15's, and then at 14.7 after a little driving. Since the Bisi Level 2 cam went in, this thing will not idle smoothly below 1000rpms.
- After reading through threads, I took off my IACV and FITV and will be cleaning them thoroughly with carb or TB cleaner. I will put them back in and let you all know the differences. If the problem persists, I will unplug the IACV once up to operating temps, and check for a falling idle. If there is no change, then I will know it's time for a new IACV. If the idle falls as it should, then I'm guessing the problem lies with the distributor or my stock O2 sensor. I am running the stock 4 wire sensor and the Bosch wideband for the gauge, which Blacktrax then decided to pin to the ECU once they got ahold of my car. I've gotten no codes for O2 sensors, but I could unplug the stock O2 from the harness and see if things change and a code is thrown.
Can anyone bring their similar experiences or knowledge to the table in order to lead me in the right direction? I would appreciate that very much. Thank you.
