Hello my fellow cb tuners. i have been trying to figure out why my car will idle good for about 2-3 days and then idle irratically. I adjust the idle screw and it levels off, then in a couple of days it's up and down.. then it levels off. Then it when it levels off it will drop below 700 rpms and tries to shut off. I have cleaned the ivac and tested it with the power probe 3, It clicks in and out like its supposed to. From what i have read on here the ivac controls the idle. So my questions to you all is, What could be causing this crazy idle. Does the ivac slowly go out or just dies completely? can it be working sometimes or not at all. i changed the coolant temp sensor. and the Map sensor.
Any advise of help will be greatly appreciated. Thanks in Advance
(Love the Frankenstein look!)
out with the old and in with the new
