We just got our car back together. We have an h22 transmission in there now. When not running it shifts very easily. When it is running and the clutch is in it will just barely go into gear. We really have to muscle it. When driving it shifts easily enough. Ww can't figure out what is wrong.
Panic transmission help
1991 Accord Lemons Race Car, "The Minnow" RIP
1993 Accord Lemons Race Car, "SpaceEx Starship"
Neuspeed Race Springs, Koni Sports, Acura CL Rear Sway Bar,
Adj Upper Control Arms -3.0deg front, -2.0 deg rear
M2A4 Trans, Cusco 1-way Limited Slip Differential, Stage 2 Clutch and 11lb flywheel. A4 Header, 2" exhaust all the way back, catalyst delete, delta 262 grind, glasspack muffler, PT6 ECU.
Acura CL3.0 Brakes Front and Rear, Raybestos St43 Pads, Redline 600 Brake FluidTags: None
We jacked it up and ran it. We now believe that the clutch is not fully disengaging. We have a new clutch in there too. It is a heavier clutch. We bled the slave cylinder. There was no air in it.
How do you adjust the clutch?Last edited by ukemike; 07-16-2016, 08:15 PM.==========================
Yes it is hard to get into all the gears. We can shift while driving (around the block once).Originally posted by Raf99 View PostDoes double clutching help? If so you have a pressure/air issue with the MC / SC that's not allowing the clutch to fully disengage to allow shifting.
OR this could be a shift cable issue too.
does this happen in all gears?
We did jack it up the front. With it in neutral and the clutch in or out the front wheels would stop turning. With it in any gear with the clutch pedal all the way down you could not make the front wheel stop at all. So when the car is on the ground and the wheels cannot turn we can't get it into gear at all.
I'm concerned that we'll need to drop the tranny again and machine the flywheel down a bit. God that would be hard to do before the race on 7/30 and 7/31.==========================
good questions. 3/4" sounds about what it looked like. I didn't measure it.
I believe we did tighten the pressure plate in a criss cross. I know we did for the flywheel, because I did that. My teammate did the pressure plate. I'll check in the morning. I'll also measure the slave cylinder throw.
My plan for tomorrow is to bleed the system thoroughly, and then adjust the pedal. We do have too much slack before it starts to engage. If those fail, I'm lost. I don't even know what we would do if we re-opened it. Install the old clutch over the new flywheel maybe.==========================
I did not drive it. Tedd, my co-owner / teammate did. But he reported it shifted a little stiff when driving. While sitting still, double clutching did not help.Originally posted by Raf99 View Post......double clutch......help ?==========================
Fixed
The clutch was not disengaging fully. We ordered a new master and slave, but those won't arrive until Wednesday so I came up with an idea. At the max adjustment the full stroke of the clutch pedal was only getting just under 0.5" of travel of the slave piston rod. There was lots of slack in the pedal before there was enagement. I don't know why, but we fixed it. I took the bracket that connects the master cylinder rod to the pedal arm off. I took the bracket to the hard ware store and found a nut and bolt that matched the threads. We use the bolt as a guide and welded the nut onto the bracket which gave me an extra 3/8" or so of range for adjustment. Then I adjusted it like ericthecarguy on youtube showed me. Then we started it up and it shifts so smooth. Like a hot knife through butter. That clutch is lots heavier and really grabs. In one trip around the block I didn't get a chance to make the LSD work but... WE ARE GOING TO MAKE THE RACE!!!! WOOHOO!
I bet that the root of the problem is that the flywheel is too thick.
Thanks everyone for the input. I was really panicking last night.Last edited by ukemike; 07-17-2016, 08:20 PM.==========================
