I installed my Bisi header literally right after I passed emissions two years ago. Well I have to go get tested tomorrow, so I fixed an exhaust leak that cropped up over the winter. We had a sh*t ton of snow and ice, hit some large ice blocks... things under the car got knocked around a bit.
Well today I got everything nice and tight again, new gaskets, new hangers, even got my rear muffler re-aligned so it's not all cockeyed.
HOWEVER, the damn Bisi header is leaking. Before this winter it was only one of the four pipes where it met the collector (lucky me, right?!). And depending on the day, it would almost be completely sealed up
Now that I have readjusted everything it's leaking like a son of a bitch. Raspy sound under the hood when you're on the gas, that 'put put put' sound... and my favorite, a raw fuel smell in the cabin (not good).
The raw fuel smell may be unrelated, however it only now cropped up (coincidence maybe?
). I'll be checking the O2 sensor, TPS, MAP, fuel pressure regulator, ignition, spark, and of course fuel leaks around the injectors, lines, and fuel filter.
So here is my question... has anyone been able to find a solution for the Bisi header leaking (besides welding it together)?
I have some lap joint exhaust clamps (pictured below).
Hesitant to even bother because...
1). Not sure they would be able to slip between all four pipes where it meets at the collector.
2). All the sh*t that needs to be removed to have access to the collector area to put the clamps on...
So if ANYONE has this god forsaken header and has a solution for the leak, post up!
). I'll be checking the O2 sensor, TPS, MAP, fuel pressure regulator, ignition, spark, and of course fuel leaks around the injectors, lines, and fuel filter.So here is my question... has anyone been able to find a solution for the Bisi header leaking (besides welding it together)?
. My plan is to get a replica one of these and sort of re-engineer the thing into a 4-2-1 to fix that mid-range dip.
