What USDM transmission would be similar to the T2W4? I am trying to figure out what axle seals to use.
T2W4 Axle Seals
Oops, I lied. I was looking at the passenger side Axle Seal, which is the same in 93 & 2000 Prelude. There are different part numbers for the driver's side.
Driver Side Axle Seal
1993: 91205-PL3-A01 001 OIL SEAL (35X56X8) (ARAI)
2000: 91201-P6J-003 001 OIL SEAL (44X60X8) (NOK)
Now I am not sure but I would guess since the T2W4 is from a 97-01 CL1 I would use the 2000 version of the axle seal, correct?Keep Pushing..
Okay so even though the sizes look like they are different it just matters about the diameter of the end of the axle?
But wouldn't you want the seal to match the actual diameter of the hole of the transmission it will be sitting in? From the sizes it just seems like the older F series seal is smaller.
I mean I am not even 100% sure that the 2000 Prelude Tranny is the same as the Euro R tranny, I just figured the years correlating would mean they are similar.Keep Pushing..
Teknotik.com Synchrotech Bearing Set
*Fits 1992-2002 M2Y4 M2F4 M2A4 M2B4 M2S4 M2L5 T2T4 T2W4 U2Q7 H2A5 H2U5 P2A5 P2U5 P2A8
For what it's worth. I put standard 90-93 Accord Seals in my M2S4 which says it takes the same bearing and seals as the T2W4.
I looked at the part numbers & it looks like (probably earlier years) 93-96 all have the same part numbers for a SI VTEC Prelude. But, when you look at the part numbers starting at 1997 Preludes, it looks like that is when they offered the SH version which is where the part number for the driver side seal changed. So I would think that if the Euro-Rs were the 97-01 series then they would have to be a similar tranny to the same years as the '97 Prelude I think?Keep Pushing..
I came across that same page, but I wasn't sure about that. I just saw different part numbers & different sizes through different years on Majestic H. & that is what threw me off.Originally posted by Rilas View PostTeknotik.com Synchrotech Bearing Set
For what it's worth. I put standard 90-93 Accord Seals in my M2S4 which says it takes the same bearing and seals as the T2W4.Keep Pushing..
I recently had to do this to my T2W4, this is the seal that I used:
http://www.rockauto.com/en/moreinfo....170201&jsn=418
On rockauto, the part numbers are common between 93-96 and 97-01.
The seal that I received has a couple of mils of additional depth compared to the seal I removed. But it sealed the output shaft.
Awesome, thanks for the info.Originally posted by SSMAccord View PostI recently had to do this to my T2W4, this is the seal that I used:
The seal that I received has a couple of mils of additional depth compared to the seal I removed. But it sealed the output shaft.Keep Pushing..
