Hi I have my 1993 Honda Accord EX wagon with the factory keyless entry system. The original key fob no longer accepts a charge from the ignition cylinder so I am trying to install my own keyless entry system. I wired everything up, power, ground and both lock-unlock signals and none of the power door locks will work with the door handle switch or the keyless entry system, if the lock-unlock connections for keyless entry are removed the door handle buttons work just fine again. I'm not the best at electrical work but I am really trying to find a way for this to work. Any help is greatly appreciated thank you.
After doing some more research it looks like I have to connect the door trigger wire for the keyless entry to work? Trying to find out what wire that would be.
Received a replacement keyless entry system from Amazon this morning. I plugged the new brain in and everything works as it should.
