OK, heres the problem. My lower radiator hose has nothing in it ALL THE TIME. Theres no leaking anywhere and the overflow res. has plenty of coolant in it. The cars never running hot. Not sure why the hell theres nothing in it ever but im sure its not supposed to be this way. Lemme know what you guys think.
Lower Radiator Hose!!
you took it off and nothing comes out?H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
Weird....there should be something in there especially since it's connected to the lower part of the rad. How do you know nothing is in there? If you have the cap off and you sqeeze the lower hose, the coolant level should rise in the rad with no air bubbles coming up. If you disconnected the lower hose with the rad still full, you should have coolant coming out the bottom of the rad and from the hose. If your car isn't over heating, then the thermostat is working.......not really sure what the problem is. If your guessing there is nothing in there becase the lower hose is colder than the upper hose after driving, then the thermostat might be stuck halfway open or something.
Let me put in my $.02
I replaced my lower rad hose roughly a year ago with a Goodyear hose from Autozone, and it too seems to have squishyness to it that the upper hose does not. My car runs fine, is full of coolant, and does not overheat.Former: 90 Accord EX Coupe, 93 10th Anniversary in Frost White
It may not overheat now, but who to say it won't later?Originally posted by ACCORDianateI replaced my lower rad hose roughly a year ago with a Goodyear hose from Autozone, and it too seems to have squishyness to it that the upper hose does not. My car runs fine, is full of coolant, and does not overheat.
You are a very wise my man... I'd hate to be stranded somewhere for a couple of hours, trust me!Originally posted by vmchurchalright, ill replace the hose and post the results....not too worried since a f22b goes in in a few months.
