So i was putting my oil pan back on last night with my shiny new gasket, and i snapped two of the bolts that hold the drivers side corner of the pan in place. So much for my torque wrench... it snapped at less than 120 in/lbs. Broke em off right at the block so I can't grip em with anything.
So, how would you go about getting the studs out? Drill n Tap, or do you think these "Easy out" bits at autozone will work?
....Just kidding, you might start a fire doing it! Is there a new bolt you can replace it with? You could use JB weld, just clean off the surface and let it cure completely... also, if you do this, becareful not to strip the drain plug thread cause if you do.... Hmm... maybe JB weld isn't a good idea after all...
