Where does my ignition coil go???
    First off I'm a new comer so not sure if this is the right place to post but, I need help on finding were my external ignition coil goes. if you got pics that would help alot. My car is a 93 accord ex with the external coil just sitting on top on the metal so the car will start next to the egr can someone help? please!!
    bizzump
      Bolt it wherever it will reach, or wherever you want it. Look in member's ride to see where others have it. Sorry, I don't have EXT coil or I'd get you a pic.
      -Jay
        I'll check out their rides!
          i made a circular bracket for mine and mounted it on the passengers side directly to the side of the black vacuum control box.
            Does any one have pics on a close up of the ext coil?
              Seriously Guys I'm Stuck At Work Cuz My Motor Is Hot It Won't Start Because My Fucking Coil Isn't Mounted To Shit!!!
                just zip tie it to something temporarily. It doesn't have to be mounted in any specific place just wherever u can fit it.
                  i knew this thread looked familiar..
                  http://www.cb7tuner.com/vbb/showthre...highlight=coil
                    I got my shit running the other day and i think it is also hard to start because my engine was warm due to the heat.(how do i fix that) but when i asked my mom all the stuff she had fixed she said she had the block replaced so i checked a friends car of the same year and type and he has a f22a6 and i have a f22a1 so no mounts for a coil.!! Should i just jimmy rig the coil to something or could i switch the dizzy to internal coil???
                      just tie it up to something, as long as the coil plug isn't coming aloose then your fine. Secure it somewhere in the engine bay is all u have to do.
                        alright i'll keep the external coil, but how do i fix the heat problem because down in houston its always hot as hell!
                          u haven't said any details of how ur motor is hot...u just said it was hot, that tells me diddly squat.
                            well i'm really not sure first in the morning off to work it starts after quite a few revs because its cold i'm guessing and at lunch turns on fine back to work fine, but then everyday day at the end of work no start it just turns and turns it is sitting in the sun so i'm not sure if that would be the problem but i hear alot of troubleshooting with this same problem.
                              sounds more like a main relay problem..
