First off I'm a new comer so not sure if this is the right place to post but, I need help on finding were my external ignition coil goes. if you got pics that would help alot. My car is a 93 accord ex with the external coil just sitting on top on the metal so the car will start next to the egr can someone help? please!!
Where does my ignition coil go???
I got my shit running the other day and i think it is also hard to start because my engine was warm due to the heat.(how do i fix that) but when i asked my mom all the stuff she had fixed she said she had the block replaced so i checked a friends car of the same year and type and he has a f22a6 and i have a f22a1 so no mounts for a coil.!! Should i just jimmy rig the coil to something or could i switch the dizzy to internal coil???
well i'm really not sure first in the morning off to work it starts after quite a few revs because its cold i'm guessing and at lunch turns on fine back to work fine, but then everyday day at the end of work no start it just turns and turns it is sitting in the sun so i'm not sure if that would be the problem but i hear alot of troubleshooting with this same problem.
