Tranny/Clutch problem??
    Ok, so i was pulling away from a redlight, not racing, just normally. The car accelerated normally for about 3 feet, then i heard a POP come from the front end of the car and it just stopped moving. Whats weird is, I can let the clutch out with it in gear and give it gas, and voila the speedometer climbs, but no movement. When i let the clutch out, it doesnt stall, sputter, shimmy, etc. Nothing.....just sits there.. Please help, its my only means of transportation.
    1996 Jeep Grand Cherokee Laredo
    4.0L I-6 2WD
    293k miles, still running strong.
    Freshly rebuilt transmission.
    cmon guys, really need some insight as to what this could be, i have a few ideas, but a fresh ones are always appreciated
    4.0L I-6 2WD
      u fucked ur dif. u need a new tranny (tu)
      92 accord dx....traded
      97 accord ex....traded
      93 civic si ....stolen
      96 tercel ....sold
      97 ek hatch b17 ..traded
      97 civic 4door b16 sold
      04 tsx traded ...for a honda coupe (top secret)
        u really think so???? god damnit...i just put that fucker in like not even a month ago
        4.0L I-6 2WD
          i would say its more likley taht something happened to your axle . . . but i dont know much about transmissions either . . .
          -Mark-
          CB7
          CD5
            axles are fine, at least from what i can see....
            4.0L I-6 2WD
              it might be the axle...sine the clutch is all the way out and it is not moving either.
              what was the condition of the clutch? another question would be...throwout bearing?
                the clutch is about 5 months old, so its still pretty new
                4.0L I-6 2WD
                  well, the axles can pop out of each other and physically look fine from the outside.
                  maybe try jacking up the car and leaving the car in gear and spin the wheel the opposite direction?
                  what are the conditions of the axles?
                    the axles are about 5-6 months old as well, when i replaced the clutch i did those as well
                    4.0L I-6 2WD
                      I know when i replaced the front axels in my accord i didn't get them all the way back in and they popped out while i was driving and it did exactly as you said, revs up, rpm's and mph's go up but you don't do anywhere. i'd say jack if up and see if by pulling the axel lightly it comes out at all, cuz thats all it could be.
                        yeah make sure your axles are actually installed properly. This happened to me and it turned out to be that the bolts that hold the intermediate shaft in place had not been torqued and vanished, letting the axle slip out just enough to be a pita.
                          ok, checked the axles, they were fine, towed it to my friends garage, we replaced the pressure plate, clutch disc, and flywheel. got it all put back together, tested in the air, everything worked. set it down to pull out, and nothing....fuck it im either selling it or parting it out....
                          EDIT:: The Axles are FINE
                          4.0L I-6 2WD
                            Yea, you fucked your diff, but don't sell or part out, just put an H22a in there and fall in love with the CB7 again.
                            JDM H22a
                            P2T4 tranny
                            I/E, CM ultra-light flywheel and CM stage 1 clutch
                            16x7 Rota C8's in bronze
                            nitto neo gen, 205/50/16
                            custom short throw shifter
                            Tokico Illumina RAK Coilovers
                            Power Stop Cross-Drilled Rotors, Honda Pads
                            Honda Torneo Shift Boot and Knob
                              ok, i have put almost 5 grand in that car keeping it running in the past 2 years...so, no, i refuse to keep this money pit of a car..oh, and its a CD5, 94 EX
                              4.0L I-6 2WD
