hey guys, i have a problem with the trans on my accord. first of all, it is an h22 if that means anything
i just got a set of brakes put on today........they have to bleed lines in order to get the fluid back in correctly.......can that be a problem? maybe that bled the wrong line? after all, brake fluid does run through the slave cylinder which feeds the clutch
also, when you put the clutch in, it stays in.......and doesnt pop back out when you take your foot off of it.....my guess is the throw out bearing. any of you got any ideas?
and to top it off, the car wont even go into gear......sort of like when the car wont let you shift gears unless the clutch is in, or the car wont start unless the clutch is in
so basically, i cant get it into gear, whick means i cant drive my car, and none of this happened until after i got the brakes installed
please help.....all input is appreciated
